VS Calais Radio Harness
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by GAMBLR, Sep 17, 2007.
  1. GAMBLR
    GAMBLR More trouble than u think
    Whyalla (yawn), South Australia
    '04 VZ Calais LS1
    Hey all
    need of some assistance pls. i have just bought a new pioneer headunit for the VS, but rather than chop the wiring up, i thought i'd invest in the iso wiring harnesses.
    Here's the problem. its a 96 VS2 Calais, but the VR-Vs Aerpro APP061 harness i bought doesn't connect to teh standard existing plug, the white piece that the original headunit connected to. It isnt long enough, about 10mm short longways. when i enquired about it, the store tried a VT harness, which fit to about halfway, but wouldn't go any further or clip in. The VN-VP wouldn't fit at all.
    Was there any difference between say a statesman/calais and an executive? has anyone experienced this problem?
    Also, i was told i needed to buy another adapter for between this harness and the new Pioneer deck. Again, is this true?
    Any help is greatly appreciated
    Thanks everyone
    CC
  2. GAMBLR
    '04 VZ Calais LS1
    hey guys quick update
    found out i needed a VT harness, and wired up the new headunit.
    Now i have the problem of the unit not turning on when ignition is on. fuse was replaced, but we have a Dash Light Illumination wire and an Auto Antenna wire in the harness with nothing to connect them to. The head unit (pioneer) has a system remote control piece coming from it.
    HELP, what should i do?
  3. NickVR
    NickVR Active Member
    Adelaide, SA
    VR Executive A4 V8
    Do you know exactly what each wire does on the Calais?
    If not here is a list for you. This is for a VR Calais though, should be the same.
    A stock VR Calais headunit has the following wire colours & functions:
    PIN 1 ....... Blue / Black trace ....... RHR speaker
    PIN 2 ....... Blue / Orange trace .... RHR speaker
    PIN 3 ....... Green ...................... RHF speakers
    PIN 4 ....... Lt. Green .................. RHF speakers
    PIN 5 ....... Yellow / Blue trace ..... LHR speaker
    PIN 6 ....... Brown / Black trace .... LHR speaker
    PIN 7 ....... Grey ........................ LHF speakers
    PIN 8 ....... Lt. Brown ................. LHF speakers
    PIN 9 ....... (vacant)
    PIN 10 ..... Yellow / Red trace ...... Pwr aerial (radio on)
    PIN 11 ..... Brown / White trace .... Illumination (park lamps circuit)
    PIN 12 ..... White ....................... Pwr aerial (up?)
    PIN 13 ..... Black / White trace ..... Electronic Ground
    PIN 14 ..... Lt. Blue .................... Pwr aerial (down?)
    PIN 15 ..... Brown ...................... S/wheel remote cont. (thru SWRC module)
    PIN 16 ..... Black / White trace ..... Electronic Ground
    PIN 17 ..... Yellow ...................... 12V switched (fuse #13)
    PIN 18 ..... Orange / Violet trace .. 12V constant (fuse #7)
  4. GAMBLR
    '04 VZ Calais LS1
    thanks anyway mate, but jus found that the resistor has shat itself. great, time for some fun then
  5. NickVR
    Adelaide, SA
    VR Executive A4 V8
    Well at least you found the problem.
  6. GAMBLR
    '04 VZ Calais LS1
    lol now its a matter of fixing it very soon. if ya cant tell im very impatient
  7. NickVR
    Adelaide, SA
    VR Executive A4 V8
    Don't worry I'm the same. I want everything done yesterday.
