Vs Calais RB25
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by NVE_069, Jul 28, 2006.
  1. NVE_069
    NVE_069 New Member
    Wh Statesman LS1
  2. Jamie_87
    Jamie_87 New Member
    2003 BA XR6
    12,000 for a vs calais with an rb26det conversion, i wouldnt pay that as u can get vs calais for around 7grand, i bought mine for 5500, with the left over $$$ i would have rather put a supra turbo engine (2jz gte or sumthing), as toyota engines are more reliable than nissan engines plus supra motor puts out alot more torque being a 3.0L(better for commo cos nissans are alot lighter, supra is closer to commo weight), still an ls1 conversion would have been my choice if i was actually gonna do a conversion.
  3. NVE_069
    NVE_069 New Member
    Wh Statesman LS1
    rb25* i didnt think u could do a conversion that cheap thats why i thought it might have been cheap.
  4. brohawk
    brohawk New Member
    adelaide
    vp calais
    yer looks aight if u wana pay that much for it. first id make sure it is certified id wana see the cirtificate then look the car over then buy it dnt stuff round with that sort of stuff for that price id test drive it etc. plus on 10 psi thats pretty ave u can normally run bout 16 through an rb25 with a big cooler.
    so in my opionion if u like it and are willing to pay that much check it first then go hard son
  5. NVE_069
    NVE_069 New Member
    Wh Statesman LS1
    i wouldnt buy it myself but yeh check it rite over for sure
  6. SaGe
    SaGe New Member
    VS II S-PAK Manual
    apparently its not too expensive and rather easy to convert to an RB25DET. i think its because the VN front crossmember was designed to hold an RB25DET in the first place, so it must be the same in a VS
  7. greenfoam
    greenfoam New Member
    VP Executive R-spec
    You put a VL K frame in them, then it's a bolt in job
  8. petezor
    petezor i like icecream
    VS COMMODORE
    also... a 1jz would be good to drop in. apparently they can handle 800rwkw on stock internals. and a halfcut is only about 2800.
  9. Pub247
    Pub247 Well-Known Member
    Melbourne S.E.
    Ford Fairmont
    I heard its more like 650 hp. Rb motor conversion would be alot cheaper than supra as said crossmembers are similar plus 1/2 jz have the exhaust other oppisote side. Putting one in a toyota cressida would give a low 13 sec quater so a commy would get about the same time
