showtime
- Feb 15, 2007
- 79
- 0
- 0
- vs 5.0l
Thanks for the help guys, I'll try this tommorow. First i'll check all the connectors and for obvious wiring issues and then If I get no where I will try testing like suggested.
One thing to add, after doing a little more driving I'm noticing that it tends to change better when cold and once warm it holds gears longer, I havn't yet properely checked if it will kick down gears when cold.
The only other thing that I have noticed that may be related (but probably not), is that the temperature guage does not seem to get anywhere near high enough. From memory my last vs 5.0ltr ran at around just under quarter normally and got up as high as over half when really getting into it. This temp guage only seems to run at just above cold and max at just under quarter.
Just after reading that a wire from the tps is also related with temp sender, Is it posible that it could be related?
