GOT IT!!
ohhhh the powaaaa!!
the WHINEEE!!!!
*laughs maniacally*
I've got a list of small electrical problems that I will need to take it back to the dealer for to get them to fix unfortunately. Some things I will do myself, but some I'd rather they pay for the replacement parts hehe.
* When they replaced window regulator, they didnt install it properly and the window doesnt sit properly in the channels (read: it will leak if it rains)
* Electric antenna is bent just enough to stop it fully retracting. I'll prolly go to super cheap and get a replacement aerial just because i dont want a half-assed "straightened with pliers" fix on that.
* Climate control when on 'auto' only blows cold air even when set on 30 degrees. However, when you select 'full heat' it goes scorching hot, so it must be a problem with the temperature detection in the climate control unit rather than the servos
* Rear drivers side reading lamp is cracked. I will try and source a plastic bit myself (btw anyone got one?
* Window washer jets only trickle for some reason.
* Door locks seem to be doing funny things, such as u can hear the locks trying to open a few more times after u press the button on the remote. I think this is because the key itself is faulty and the unlock button is sticking or something, because it stops after a short while and when the key isnt near the car it doesnt do it.
But even with its little issues,
:yeah:
