VS Caprice consol question
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by coolngroovy, Mar 1, 2008.
  1. coolngroovy
    coolngroovy Member
    Mackay Qld
    MY06 VZ Calais
    Hi guys, can anyone tell me if the shifter surround for the ^ is able to be removed/replaced, or is it an actual part of the whole consol?
    Also, the woodgrain compartment cover in the centre of the dash, can the cover be replaced? Or do i need to buy the whole surround?
    Cheers, Col.
  2. Nobody Actually
    Nobody Actually luxo barge
    Queensland
    2007 wm Caprice
    it is able to be removed in both instances. but be sure to be committed since they are both glued and plugged
  3. coolngroovy
    coolngroovy Member
    Mackay Qld
    MY06 VZ Calais
    Do you have any tips?
    Is the auto shifter surround glued?
  4. Nobody Actually
    Queensland
    2007 wm Caprice
    it should be, my tip is go slow so you don't bust it up entirely
  5. coolngroovy
    coolngroovy Member
    Mackay Qld
    MY06 VZ Calais
    It's already broken from the PO.
    I need to source a new part & fit.
    The car doesn't arrive til the end of next week, so i'me trying to do some homework before it gets here.
    Cheers, Col.
