VS Caprice cruise control probs
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by coolngroovy, Mar 1, 2009.
  1. coolngroovy
    coolngroovy Member
    Mackay Qld
    MY06 VZ Calais
    G'day all,
    I took a little cruize 400ks down the coast. The cruise control was playing up on the way down.
    On the return trip, it refuses to work at all.
    The light on the dash is on. I cant turn it off. None of the other buttons on the stalk are working either.
    Any suggestions on where i should start looking?
    Cheers, Col.
  2. vsl67
    vsl67 Member
    VS l67 statesman
    Which light? there are 2 is the the green one or the orange one ? One of my cruise control lights on the dash blew once ,it made it near impossible to use the the cruise control as I had no way of telling if it was on or off
    Also there is a swith under the exelerator check to see if its not loose and cancling it out,this happend in my VP
  3. _R_J_K_
    _R_J_K_ Well-Known Member
    Zenki S14
    Although this is most likely not causing your problem, make sure all of your brake lights are working properly. If there is a blown bulb, cruise control will not work.
  4. coolngroovy
    coolngroovy Member
    Mackay Qld
    MY06 VZ Calais
    The green 'ON' light is constantly lit.
    I cant switch it off.
    The brake/cancell switch is intact.
    I will check the bulbs tonight.
    Thanks, Col.
