VS Caprice electric seats question
shanhsv
Luvo
Muswellbrook, NSW
VSII Calais V6 & VSII Senator 215i
I know they bolt straight in how are the electric made to work.I have the fuse thingy for it,does that mean theres a plug for it tucked away somewhere?
Haydz
Fasten your seatbelts
Liverpool.Sydney,NSW
VS UTE LS1 T56
they dont bolt straight in.
one of the bolts is different.
and depends how you want to wire it up.
in my berlina i run it straight to the battery but fused.
in my caprice it runs even when the key is not in. so there is a relay that runs them
shanhsv
Luvo
Muswellbrook, NSW
I totally forgot you have it done Haydz. I tried looking it up and people just said that the seats fit straight in,how would i adjust that 1 bolt to make them fit.
Haydz
VS UTE LS1 T56
well the hole is there. it has just been filled. the way i done mine was to drill it out and replace the last alan key head bolt with a standard nut and bolt setup. just make sure you get nylox nuts or you will be forever tightening them.
statesman seats though will fit straight in.
personally i would probably just go statesman seats over caprice one's but its up to you.
shanhsv
Luvo
Muswellbrook, NSW
The seats im eyeing off would look great in my car,same colour as inside and in good nic, bit pricey tho so i may indeed take your advice and get stato seat,just waiting to see how may finances go till mid next month before i decide,but i'd look up everything first.thanx again mate
