VS center bore size in millimeters
graham7773
VT Acclaim Wagon
I have just spent an hour searching this and can't find it on these forums or the web...what is the diameter of the VS road wheel center bore?
VR38
VB SL/E
AFIK Commodore Centre hubs are 69.5mm pre VE and 66.9mm VE.
Doesn't answer your question but hope it helps.
graham7773
VT Acclaim Wagon
Thanks for that, problem solved
EDGE3
NEWCASTLE
1997 VS COMMODORE,1996 GTS-R COMMODORE
VS center bore size is 120mm
BlackVXGTS
Melbourne, SE
DBA rotor catalogue shows the VS centre hole as being 70mm and VT-VY as being 71.5mm. Not sure if this is the same as the wheel centre bore size.
EDGE3
NEWCASTLE
A center bore hole is the hole on the inside of the wheel which is 120mm for the VS
VR38
VB SL/E
Double post sorry.
VR38
VB SL/E
Think about that, the stub pattern is 120mm PCD, where would the wheel studs line up with a 120mm hole in the centre of the wheel????
EDGE3
NEWCASTLE
The center bore isnt the actual size of the bloody hole I know that,what Im saying is that halfway from one stud to halfway to the furthest stud is how you measurer the center bore which is 120mm for a 5 stud pattern.This part of the wheel is called the center bore.
graham7773
VT Acclaim Wagon
I didn't mean to start WW1V but the center bore I was referring to is the hole that sits over, (or locates on) the bearing hub. Bear gave the size as 69.5 for the VT and I believe the VS is the same except for the part the brake disc locates on which is larger. Pax. Maybe should have simplified it by saying "the hole in the center of the wheel"?
