VS climate control MODE Question.
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by VS_Pete, Nov 18, 2008.
  1. VS_Pete
    Hi all,
    I push my mode button to get the air to come out of the top vents no go.
    I slap the side of the console and it works.
    Is it the climate control unit or is there something behind it like a vaccum tap???
    How do I fix it??
  2. vsl67
    vsl67 Member
    VS l67 statesman
    sounds like the vacuum block is stuffed read the reply I gave rabbit heers
  3. Surfwagon
    Surfwagon Well-Known Member
    Sydney/NSW
    AMG Mercedes C63 Wagon
    Mine does the same and I use the same bang method to get it back.
    It is as vsl67 said the vacuum block porblem and the remedy is to replace it.
    I have bought my new one but as yet haven't had time to fit it.
    Holden part#92140248 solenoid vacuum about $100+.
    Cheers SW
  4. VS_Pete
    Cheers guys
  5. Surfwagon
    Sydney/NSW
    I fitted the solenoid about 2 weeks ago and the AC has worked perfectly since, no more closing of the vents and have to bash the console to make it start working again.
  6. Surfwagon
    Sydney/NSW
    Just spent 4 x 30+degC days on the road travelling between Sudney and the mid north coast and the AC performed faultlessly.
    Will post up a pic I found of the location of the solenoid when I get home from work.
    SW
  7. 98scstato
    98scstato New Member
    Gold Coast
    1998 VS Statesman 3.8 Supercharged
    hey i have the same problem, can you post that pic so i can replace mine, thanx
  8. NORTI
    NORTI Crazy VS lady
    Gen 2’s
    bump for pic.... please?
  9. 88GreenVN
    88GreenVN Next Exit Left
    Surprise, Arizona
    Dodge Ram Van 1500 5.2 V8
    The solenoid pack is located under the front of the heater box - basicly below the radio almost at the floor lever of the tranny hump
  10. NORTI
    NORTI Crazy VS lady
    Gen 2’s
    yeah found it now.... lols
    are the boxes the same VN-P-Q-R-S?
  11. Chirpstr
    Chirpstr A new project attack
    VR Berlina M5, VP M5
    Norti, I have a spare good working solenoid block if you want. PM me if your interested.
  12. NORTI
    NORTI Crazy VS lady
    Gen 2’s
    hell yeah, not entirely sure thats the issue, but Id love to swap it out & test my theory!
  13. 88GreenVN
    Surprise, Arizona
    I have a spare in the shed (ready for the 89 sedan) if you want to drop in to my work.
  14. NORTI
    NORTI Crazy VS lady
    Gen 2’s
    will it be the same as the VR?
  15. 88GreenVN
    Surprise, Arizona
    Got this setup out of a VS ... so yep think so.
  16. NORTI
    NORTI Crazy VS lady
    Gen 2’s
    awesome, Ill have to get Ben to drop in for me, Im on lates. What time you there til?
  17. 88GreenVN
    Surprise, Arizona
    Between 10 and 4 - I'll have the white VZ
  18. NORTI
    NORTI Crazy VS lady
    Gen 2’s
    Im having a blonde moment, where in Seaford is your office again?
  19. ChoppaReid
    ChoppaReid New Member
    VS Series II Supercharged Statesman
    AirCon on a VS Statesman (not the VAC PAC)
    Guys, I am hoping a legend in here can help me.
    I have the problem where vents are pointed permanently to the floor.
    in current 35+ degree heat this is killing me and my kid.
    Holden have tested all cabin gear (AC Unit, VacPac, connections) and all is good.
    They say the vac hose in the engine bay may not be connected which is possible because I had LPG fitted by a shonk dealer during winter and have found many things NQR.
    Can anyone tell me (preferably with pics) where in the firewall AirCon vac hose comes out, and where on block/head/solenoid etc the bastard hose fits to?
    I am confident this is my problem because I saw several hoses left clamped off while the guy was installing the LPG.
    pwetty pwetty pweese be someone in here that knows this and can share it.
    I have the holden original VS SuperCharger supplement manual and it is as useless as tits on a bull to me for this.
  20. VS_Pete
    This is the best I could do I hope it helps I didn`t pull this car apart but I think it will give you an idea.
    pics in order
    1. line comes into engine bay passenger side.
    2. runs along firewall.
    3. goes into cabin near heaterbox inlet/outlet pipes.
    4. tee piece must be the line ??????
    5. and they go on here.
    Good luck.
