VS Climate Control not Working Urgent Help please.
calais_SC6
L67 VS Calais
Hi Guys,
My climate control isn't working, basically nothing is coming up on screen (main screen) but the buttons on the bottom lite up?? no heater or cool air of A/C works, went to the mechanic and he tried another climate control unit and it did the same thing didn't work.
He also said to check if its getting power? how do l check that? It is a late 97 VS Calais.
any help would be greatly appreciated.
cheers
calais_SC6
L67 VS Calais
bump!
somebody got to know the problem please.
calais_SC6
L67 VS Calais
anyone??
it get tough to drive especially when it gets foggy....
cheers....
MontieVHSL/E
sydney
VH SL/E 304 (injected)
I would check fuse 17 as its the ignition fuse that runs the climate control panel also fuse 1 witch is the battery fed fuse for it. otherwise send me your email and i will send you the wiring diagram
Philthy
That dent guy
www.qbdentfree.com.au
3.0R Liberty, XC Falcon
I had this problem a while ago, but I'm not 100% sure how I fixed it. I remember that one of the plugs on the back takes more to push in than it's 1st "click" but I have a feeling I figured that out before this problem came up. I ended up replacing the control unit and also the solenoids under the headunit, but I cant imagine replacing the soleniods would have helped that particular problem.
So there you go, I don't think I helped at all
calais_SC6
L67 VS Calais
hi guys,
tried all that, but with no luck.
Chirpstr
A new project attack
VR Berlina M5, VP M5
Replace the "LP. CHK" Relay in relay box.
calais_SC6
L67 VS Calais
already did that, but with no luck.
any other ideas?
