Vs clubby irs diff knock issue
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by mr_clubby96, Oct 19, 2008.
  1. mr_clubby96
    mr_clubby96 New Member
    vs clubsport
    hey guys i just jacked up and had a proper look at it its i turned the wheels and jolted em rite n left quick and noticed a ching ching sound from the tailshaft uni joints also when i spin the wheels constentetly i heard a hissing hissing sound from the diff also i took it for a drive off the clutch to creep forward and knock reverse the same knock again on n off the accelerator still knocks and between shifts it knocks and the car bogs down once it happens does it 1st 2nd 3rd not 2 sure about 4th gear or 5th didnt hear anything its manuel 5speed
    does anyone know im getting it checked out soon
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    You really need to get the car on a hoist or at least on ramps and get underneath and check every universal joint and the centre bearing which has a constant velocity joint. The hissing sound could be coming from a failed centre bearing rubber support allowing the tailshaft to rub against the side of the centre bearing....could also be the upper control arms on the back axle or a dozen other item but the only way to pinpoint the culprit(s) is to inspect.
    Just be prepared when you get it checked by a suspension shop that they probably will report "everything" that has wear in it - that means every flexible joint from the transmission back...rubbers, insulators, unis, c.v's and mounts. The repair bill could be considerable. If you are lucky they will isolate it down to exactly what is causing your problem....but just be aware! Good Luck.
  3. mr_clubby96
    vs clubsport
    thanks bro im getting it inspected from a diff speacilist
    then il take things from there cheers bro
