The Whale
- Jan 28, 2021
- 10
- 1
- 3
- Age
- 74
- Location
- NSW
- VS Clubsport
My VS Clubby 5 speed occasionally overheats and dumps around 2 litres of coolant from the overflow tank.
Over the last 12 months I've fitted a water pump, a new alloy radiator, replaced the temp sender and sensor, all the hoses, including to / from the heater, all the clips, the thermostat, and caps of the correct rating on the radiator and the overflow tank.
After all that work, a 30 minute drive on a 30 deg day with the aircon operating, and the auxiliary thermo fan also operating, results in the indicated engine temp increasing from its usual 25% FS to 50% FS.
When the engine is then shut down the radiator can be heard gurgling, and coolant spills into the overflow tank, and from there overflows onto the ground.
Once cooled down the radiator takes around 2 litres of coolant to fill.
I don't know where to go from here, so all help and advice greatly appreciated
