Vs Clutch Issues
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by 10wvs, Aug 15, 2005.
  1. 10wvs
    10wvs New Member
    VS Executive S2
    Hey all
    Just wondering, i have a VS S2 Executive 5spd and its time for a new clutch...now i have called a few places and apparently there is a high possibility that i have to replace the dual mass flywheel at the same time i have to replace the clutch because the dual mass flywheel fcuks up.
    The quotes i have got have averaged $1900 to replace the 2. Has anyone else come across this problem?? is there any other alternative ie use a single plate flywheel from another car?? also does anyone recommened somewhere in brisabane to get the clutch done??
    Andrew
  2. Fekason
    Fekason Fekason
    Penrith NSW
    There are options.
    First, I believe that $1,900 is too much.
    I have recently had mine done, and used the nearest brake/clutch place for $1,450 installed.
    It is possible to replace the dual mass flywheel and use a different clutch kit. I could have converted for $1,100, with subsequent changes just requiring a clutch kit.
    However, I was told that it had a very noticable rattle at idle.
    Since this was the first unscheduled maintenance in eight years, I decided to stay with the stabdard equipment.
  3. Fekason
    Fekason Fekason
    Penrith NSW
    More Info.
    Hi,
    Further to my note last night, try:
    http://www.exedy.com.au/store/default.pl
    I believe that they sell a solid flywheel replacement clutch system. They will also point you to companies that sell and install same.
    As I said, I believe about $1,100 sees the job done with this change, and about $1,450 for the standard system.
    Cheers.
  4. VT-565
    VT-565 New Member
    QLD
    VT
    it's not the fact that the dual mass flywheels stuffs up, it's just that you cannot machine it like you would a single piece when you replace your clutch. i have recieved a quote from mal wood auto for $950 for heavy duty clutch and single piece flywheel.
