VS Clutch Slipping?
Zarconia
Outrageous Fondler
Rockhampton
2010 R8 Maloo
Gday fellas
Just some Q's about my manual trans seeing as its the first proper manual ive had i cant tell what is actually going.
Driving giving it a bit going from 1st to 2nd engine revs alot then slowly creeps into gear same with 3rd im assuming the clutch is giving out?
Going from 1st to second unless it gets to 2000rpm the car will shudder as if its about to stall
Also when dropping from 3rd to 2nd its dosnt feel as if its gripping alot and gives of a grinding sound
Please tell me its just the clutch and not the flywheel or worse, gearbox :(
tezza
VX SS
Sounds like the clutch, just find a moderate hill, shift into 4th gear and accelerate hard. If the clutch is slipping, the revs will rise although the car will not really go anywhere.
When the clutch is replaced, the flywheel will be machined anyhow, although depending on the condition may need replacement.
Zarconia
Outrageous Fondler
Rockhampton
2010 R8 Maloo
Allright, cheers mate will book it in for a service and tell em to take a look at the clutch
GTP 85
291 hp @ the wheels
35
Murray Bridge S.A
MY04 WRX, VS SSenator & VS V6 track weapon
Expect a hefty replacement bill... Its a series 2 v6. Hope u have a few grand in the pocket?
Zarconia
Outrageous Fondler
Rockhampton
2010 R8 Maloo
Dont say that =[ i dont like big numbers =[
justbad4you
IF YOR NOT A HOLDEN
MELBOURNE S/E BAYSIDE
97 VT BERLINA/ 98 VS SIII MALOO (RED) LX SLR5000
Zarconia
Outrageous Fondler
Rockhampton
2010 R8 Maloo
Is that just for the clutch or labour? Im going to chuck a heavy duty into it if im able too.
justbad4you
IF YOR NOT A HOLDEN
, its not that hard to do if you have a little mechanical knowledge or have a friend who can...OR Yep, pretty much. Just take the old flywheel out and machine.OUCH, unlucky mate the getrags are expensive when you do the clutch. it cost my mate $900( THATS CHEAP) to replace the clutch and flywheel is his vs ute, luckily mines fine atm touch wood, It is so expensive cause the flywheel alsohas to be replaced or machined (possibly), not sure if a T5 clutch will fit it but im thinking it wont
OR
Zarconia
Outrageous Fondler
Rockhampton
2010 R8 Maloo
I probably could do it myself if i found a tutorial on how to do it, but i think id rather pay someone else to do it to make sure it gets done properly
justbad4you
IF YOR NOT A HOLDEN
yeah if ya not 100% lets some 1 else do it.....and get a warrenty....cheeeers
