VS coil pack on VN?
Ayla
VN Series l
Just wondering could you put a VS coil pack on a VN?
Shearer
VY SS ute
Yes you can. Bolt off, bolt on :)
EDIT: Refer below
UNDERCOVER HQ
HOT 202
townsville
VN BERLINA 202
Coil pack
They are diffrent you can ghange the tops. Two little screws either side of the coil will un do them. The hole bottom bit and bracket is diffrent.
88GreenVN
Next Exit Left
60
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
I've just fitted a VR set of coils to the 88 wagon - just need to get the leads in the correct order.
Izual
Shepp
VR Series 2 Executive
VS coil pack will not fit as the bottom bolts are different. VR coil packs will fit on thought. They have the VS style coils (3 groups of 2 plugs able to be removed separately ) but still have the same bolts as VN underneath.
Shearer
VY SS ute
I stand corrected. The VS coils and module will only fit if you have a mounting bracket from VN2-VR. VS coils screw into it's only bracket with the module sandwiched in between.
