Scoobs214
- Feb 6, 2021
- 9
- 3
- 3
- Age
- 42
- Location
- Sunshine Coast
- VS Executive Sedan S1 6 seater
Morning guys,
I want to remove my dash cluster to replace all the bulbs and put in new odometer gear. I have a column shift so I can't drop the steering wheel to make it easier to wiggle the cluster out. Are there any tricks or do I need to pull the steering wheel?
I've read that I may only have to remove the bottom and top plastic shroud on the steering column which may give enough room?
Is there any how to guides on here that you can point me to pls?
Is the dash removal just the two screws or do I need to remove the whole plastic fascia covering the cluster and vents etc?
Thanks heaps!
Thanks heaps!
