VS Commo Burnout
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by ETH4N, Jun 3, 2010.
  1. ETH4N
    ETH4N Project VS
    Central Coast (Watanobbi)
    1995 VS Commo
    Hey guys, i used to have a VR commodore, 3.8l, used to be able to put my foot on the brake, and sit there and bag it up, but now i have a VS commodore 3.8, when i sit on the brake and pump the accelerator, she doesnt bag up, barely does a spin, just revs...
    Am i doing somehting wrong??
    LOL
    BTW, these are performed on PRIVATE PROPERTY, AWAY FROM OTHER CARS/PEOPLE
  2. moff_man
    moff_man operation HQ under way.
    95 VR II berlina wagon v6, 72 HQ ute 253
    grippy tyers, thats all im saying unless it has something to do with lack of power
  3. DavoVP
    DavoVP New Member
    weclome to ecolump land my man.
    Good luck ;)
  4. iaydemir
    iaydemir Donating Member
    VY V6 Berlina
    Was the VR live axle or IRS? Is the VS IRS?
    Its easier to break traction in live axle car compared to an IRS car.
    It's a bit tricky to explain but in an IRS car the rear squats when you put power through, IRS was designed to improve handling.
    Live axle doesn't squat and has no camber, hence easier to break traction.
  5. Mattimus
    Mattimus New Member
    VS Executive S1
    My Ecotec VS bags up easy as hell, with that being said it is a live axle model.
    So unless like iaydemir said about the IRS thing, perhaps your car isn't running at it's full potential.
  6. benno9911
    benno9911 Donating Member
    Warrnambool
    03 VY S2 Exec
    go buy your self 2 brake line clamps and put them on the back brake lines problem solved just rember to take them off after your done
  7. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Back in the old FJ days (with a 65hp engine), a mate of mine rigged up a drip feed system which dripped old engine oil on to one of the rear wheels on command. Tyres of course were skinny crossplies usually bald or regrooved. They smoked beautifully and retreads basically exploded.
  8. bandidoben
    bandidoben New Member
    south yarra
    Vs wagon
    VR / VS totally different engine.
    VR has alot more Torque down low. where as the VS has more top end.
    if you want to just do stand stills on a stock car buy a VR unless you can learn to control it properly then you wont need the breaks as much
  9. Reaper
    ROFL.... suuuure...... ;)
    Reaper
  10. pac23
    pac23 New Member
    VX S-pack
    hey mate,
    i think most of the reason would be the IRS they bog down when under acceleration and when you try do brake jobs.
    I tried many times with my VS only way to do is start them spinning before you jump on the brake.
  11. [p]wrr-247
    [p]wrr-247 Mr14ry
    near blacktown
    Vz Calais v8
    lol my vs does them pretty easy get ur car looked at
  12. old mate
    old mate New Member
    Gippsland, Victoria
    VB Sedan / GU Patrol
    how many revs does it go up to, could be a trans issue.
  13. VS-S-PACK-UTE
    VS-S-PACK-UTE New Member
    VS Commodore Ute
    HAHA thats worthy of a sig.
    Get a manual and she'll drop bangers no problem ;)
  14. low vs
    low vs New Member
    Brisbane Aus-loganlea
    96 VS V6,98 VT 5.0 CLUBSPORT,VS V8 UTE 5 SPEED
    jus hook up ur window washer hoses to the back wheels and feed window washers desil
  15. VZ57SSZ
    VZ57SSZ Member
    Central Coast
    MY16 VF Series II SSV
    doubt its the IRS my old VR had an IRS LSD and it lit up both rears and just sat there with ease, the VS does them easy enough but not as effortlessly as the VR used to, however my VS is easily quicker on the freeway.
  16. Andrew426
    Andrew426 Active Member
    New Plymouth, New Zealand
    VP calais, VR Berlina, VJ valiant, BG5 legacy
    While the buick and ecotec are different engines with different torque curves, it sounds more like a trans issue to me as he says it just revs and spins a little. How is your trans fluid?
  17. Nzpure
    Nzpure VS L67
    Christchurch
    1997 Vs Supa6
    My filthy old vs wag could get the wheels going easy thinkies theres something wrong with your vs cuz
  18. dumpedvs
    dumpedvs sheppa8
    Vx S
    my vs bags em up just when you plant it,
    im guessing the mini spool would help a little :p
  19. Beno1982
    Beno1982 Beno
    Clermont
    VX SS 5.7L M6 sedan
    i had a similar prob before i converted mine over to manual......whenever i tried to wick it up the car would just rev it arse and off and slowly creap forward, i replaced brake pads and problem solved, wicked up no problems, i suggest if you want skids though put a manual in it you won't regret it.
  20. shifty6
    shifty6 New Member
    VS Exec 5spd
    the tranny in ur vs could be crap,
    maybe the rear vs brakes are working better than ur vr brakes were,
    stickier tyres...
    not really good for ur driveline anyway.
