vs commodore air vent moveing?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jas98, Aug 20, 2008.
  1. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    hey guys i just noticed that the air vent i teh dash on me VS (the one above the air con switch etc) moves around like its not screwed in etc...
    i have herd this is a common problem wit age ....how do i fix? do i have to replace the whole dash fascia thing or ? its not like the common thing where the vents itself move around its the whole unit that holds teh vents
    cheers
  2. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    The little tags that the screws go through in the surround have a habit of breaking. You will need to another vent assembly and replace it. Easy enough to do. Take the fascia off and undo the screws that hold it in.
    Is it just the vents themselves or the surround that moves?
  3. jas98
    jas98 Active Member
    maryborough QLD
    yeh the vent assembly/surround moves as one....vents stay where tehy should be (in teh assembly) ...my mates is doing teh same and he said it was some tags out the back that are broken or something
    cheers
  4. Not_An_Abba_Fan
    Bunbury, WA
    Strange Rover
    Once you take the fascia off you will see what I mean. There are 3 screws (I think) that hold it. Sometimes the the bits where the screws actually go into in the back of fascia break off. It's only two screws above the speedo and some clips that hold the lot in. You will have to undo the light switch first though by rotating the outer surround.
  5. markovr
    markovr Well-Known Member
    northside brisbane
    07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
