Vs commodore idle problems and back firing
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by jakek11, Jul 19, 2012.
  1. jakek11
    jakek11 New Member
    96 VS Commodore 4.2 Ltr
    Hi,
    I started the car after nearly 2 weeks of it sitting and i can't help but notice the cars running like $#!T . It's idling rough and back firing when it's reved??
    I changed the pod filter back to the standard box the other day because i'm selling the car. I cleaned the MAF sensor and checked vac hoses. I have run diagnostics on the car and got error codes 32 and 97 which are Manifold Air Flow Sensor and Canister Purge Solenoid. Whats the go???
    Cheers.
  2. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    Code 32 would probably be causing it to run crook. Check out the MAF (mass airflow meter), maybe try another MAF unit, also check its wiring and connectors etc for any problems. When I was getting code 97 on my VS, it was badly misfiring at cold startup. I replaced the purge cannister soleniod at the rear of the engine and its been good ever since, starts perfectly, hot or cold.
  3. Greggles_VS
    Greggles_VS The Noob
    VS Acclaim V6 Ecotec
    Remove and unplug your MAF run the car for about 20 seconds turn it off reconnect. Sounds stupid but it worked on mine. Plus check your vacumme lines.
  4. jakek11
    jakek11 New Member
    Still got the problem. I noticed the temp gauge isn't working anymore, stopped working when the car started running rough?? what could that mean? I replaced the thermostat and the colant temp sensor next to the thermostat housing. I reckon i need to test the sensors from air flow to oil. How is this done? multimeter, and what should each sensor read? Thanks, Jake
  5. michealh877
    michealh877 New Member
    perth
    stock standard vs
    I'm having the same problem . I thought it was electric so changed plugs leads coil packs and module under it then changed crank angle sensor . And still running like crap . To a mechanic on Tuesday to see codes hopefully easy fix
  6. michealh877
    perth
    stock standard vs
    Took mine to mechanics today and he said its the air sensor thing closest to the air box and a couple of injectors . Sorry for the lack of car lingo but I'm the kinda guy that's like " that's broken well fix that ( pointing )" kinda guy . Any one know how much injectors are and where to buy ?
  7. Brett_jjj
    Tamworth NSW
    vs commodore
  8. michealh877
    perth
    stock standard vs
    Cheers . Where abouts is this purge canister solenoid ? My mechanic said something about purge but he mumbled the rest . I'm also buying a diagnostic scan tool to save the hassle of taking it to him all the time .
  9. michealh877
    perth
    stock standard vs
    Part number for purge solenoid? And who makes it Bosch fuelmiser etc ?
  10. Brett_jjj
    Tamworth NSW
    vs commodore
    The GM part number for the canister purge solenoid is 01997210. I paid $120 for mine through the local holden dealer.
  11. michealh877
    perth
    stock standard vs
    Would the car work without MAF meter and purge solenoid ? I had all air sensors unplugged and solenoid at same time and car ran a bit rough but nothing like how it runs every so often when it shits itself . I'm gonna take it to a auto electrician on weekend its gotta be something else ......
