VS Commodore just started shaking
dozo77
VS v6
Hi,
Yesterday I got in my commodore to go to work, when I drove off the car seemed to be a bit lumpy, like a vibration, I thought maybe its cold. Half way throught the day I drove it again and the shaking seemed bigger, espessially when at low speed. There is only a small problem when the speed is up, and a large shake when the speed is down. There is no problem with acceleration and no sputtering. In the afternoon I had to reverse and this is where it shakes the most. In the evening I took it for a drive when I had more time and all the above was consistant.
Any ideas?
skappascrap
Herp is for the derp.
'02 VY SV8
If its not coughing and spluttering then it shouldn't be from the engine itself..
Maybe some part of the driveline mounts, tailshaft perhaps?
Mine vibrates the car when the engine is under load at 80, so I reckon my problem is similar in a way.
Sent via iPhone 4 using Tapatalk.
ephect
Donating Member
VS Acclaim V6
Going for CV joint on one of ur axles or centre bearing is shot
vrsprspt
Series 1 VT Senator
Had a similar problem and turned out my engine mounts were shagged
Wozza
VR_GS commodore
Hi
check the engine mounts, if the metal pin has sunk all the way to the frame mount then you will feel every bump and grind of the motor...its more noticeable in reverse and idle.....ramping up to a slight buzz as speed builds up
lol vrsprspt was faster on the keyboard :)
