vs commodore no throtle responce
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by tony56ss, Oct 7, 2012.
  1. tony56ss
    tony56ss New Member
    nairne
    vs commodore
    hello i have 96 vs v6 duel fuel it has problem loosing throtle responce. at the start running either fuel when slowing down the throtle would disappear like the cable disconnected ,turn the key off and start striaght away all good. the engine would be idling and not rough sometimes stall right out .now when i give it full throtle it does the same ,pull over goes into first gear all good again .try it several times both fuels same responce no throtle responce ,dose anyone have any sujestions thanks tony
  2. Ghost
    Ghost Donating Member
    Junee New South Wales
    Vs Commodore berlina Sedan 1996
    Looks like a throttle position sensor try replacing that
  3. tony56ss
    tony56ss New Member
    nairne
    vs commodore
    tried another second hand one because i thought the same no change thanks
  4. Ghost
    Ok well it's still starting so you may be looking at the following dfi module, coil packs,spark plugs, crank angle sensor, fuel pump, those cars are always a pain to diagnose does the engine light come on if so check for error codes using a paper clip
  5. The1
    The1 A Memcal a Day Keeps..
    QLD
    VS V6 Berlina Auto
    as Above check for error codes and go from there.
  6. tony56ss
    tony56ss New Member
    nairne
    vs commodore
    thanks i will check error codes but have not had much joy with those in the past
    no engine light dose not come on
  7. aussie4life11
    aussie4life11 Keep It Simple Stupid
    Western Australia
    94 vr 3.8l v6 Auto Acclaim, 2002 Vy Exec Auto
    as above your either losing fuel,air or spark. have you checked you MAF?
  8. Ghost
  9. tony56ss
    tony56ss New Member
    nairne
    vs commodore
    hello again today checked error codes comes up with 12 witch indicates no errors have tried second hand maf and throtle body still the same dosent crank angle and coil pack just die the leads and plugs are new has anyone had same problem thanks tony
