Vs commodore, rough idle then cuts out.
Brbl
30
Shepparton
Vs commodore
Been trouble shooting my vs, idles extremely rough then cuts out, also makes a hissing noise when started. Did a visual inspection and seems to be missing an air hose on the side of the engine manifold near the carburettor. Does any one know exactly what’s supposed to connect here and how it works?
ephect
Donating Member
VS Acclaim V6
If what I'm seeing is correct, that manifold is off a VT, and that hole should house the erg pipe. It's not setup or used in the VS and can be blocked off.
If you pop the 6 hex bolts on the plenum, is that hole blocked or open?
If open that's your main issue to fix first. if not try to pinpoint the hissing location
Brbl
30
Shepparton
Vs commodore
Okay cheers mate, yeah that hole is open.
