Vs commodore Ute 5l manual wont grab 1st or reverse
brockkkk
24
Newcastle
Vs Ute
Hi I’ve recently bought this Ute and it’s just having problems with first gear and reverse all the other gears work, old mate I bought it off put all new fluids in so I thought it might’ve had air in it I’m not sure sometimes they work and then they won’t just first and reverse all the others are good and it’s never happened before
Trevor loves holden.
vs commodore
Get under and look at your shift linkage maybe its worn, see if you can shift it in first or reverse from under the car..
stick3
newcastle nsw
vz sedan vs ute gsx1400
its a guessing game but could be clutch when it hard to get into gear what year was it made there are two different manual gear boxes vs came out with
is the clutch operated by cable (t5)or hydraulic (getrag)
gtrboyy
vt ss & lc gtr
Check or replace rubbers in shifter linkages might be perished.Other than that bleed hydraulic clutch setup then see how it goes.
Getrags are noisey clackers when got decent mileage on them so change oil in g/box.
Those are easier things to try first.
BlackVXGTS
Melbourne, SE
Try selecting second or fourth gear. Then move the lever straight into the gear that you want (first or reverse). Not a permanent solution but could make it a little easier for you in the short term if it works.
