Problems with my VS (I still love my car and wouldn't give it up for anything)
1. Tyre shuddering at 100Kph, front hubs replaced (under warranty)
2. Wont drive as if in neutral, reconduction automatic box (under warranty)
3. Leaking power steering oil, hose faulty (under warranty)
4. Leaking power steering oil, seals in power steering pump
5. Differential noisy, new diff bearings, back wheel bearings etc
6. Loud bearing noise from engine when cold, new idler wheels on the engine belt
7. No Aircon or demister, engine start check relay faulty
8. Aircon no go, regas and service
9. Heater pipes near driver hot when on cold temperature setting, new heater shut-off vacuum switch
10. Engine wont start or wont turn engine over, new battery (every 3 years to the day !!!)
11. Battery not charging, battery charge wire on alternator corroded off.
12. Engine makes a loud shuttering noise when you take off fast, passenger side engine mount broken
13. One loud banging noise during side to side cornering, renew the front and back stabiliser link rubbers
14. Steering is wandering and passenger wheel loose, renew tie rod end.
15. Turning indicator will not automatically turn off, change the plastic horn power ring under the steering wheel
16. Changes to high beam intermittently, change the indicator, high beam switch
17. Indicator light no go, new flasher relay
18. Car won’t accelerate properly and lacks power, spark plug leads are loose on the plugs or coils, renew the sparkplug leads (I have a permanent solution for this problem)
19. Top roof lining is coming down, renew lining (new lining has better underlay)
20. Seat makes a ticking sound, take seat out and tighten bolts on either side
21. Steering is heavy when car is hot, new power steering pump
22. Loosing water when hot, renew radiator cap
23. Car shudders above 60kph, wheel rim out of shape, renew
24. Brake pads only lasting 20-30,000 Km, Cheap pads use the original GM pads
25. Oil leak from engine block on the passenger side, not worth fixing this problem
26. Radiator, engine belt and power steering hoses replaced every 3 years for preventative maintenance
27. Fished out each inside window seal (all six, two front and four back) from inside the doors and refitted with contact glue
Les
