vs crash pad/dash pad removal
chasnu
vs ss commodore
hey does ne1 know if u can remove the dashpad without removing the hole dash in a vs commodore?? and if so how do u do it??????
ElDubya
Mad As A Meataxe
50
Yamba. NSW
2011 VE Commodore V6
Sorry buddy, that whole top section of the dash is one piece.
vs18s
Young, NSW
VS acclaim S2
can i remove my dash without the airbags going off ... like the passengers side
do i just remove the fuse
thanks
eurekamad94
street kiddo
qld
kitted, tuned, sick pantha VS
disconnect the battery (you should do it when playing with electrics anyway)
NeilB
VR Caprice
Always disconect the airbag via battery,fuse and the yellow connection.
WARNING: The airbag can still go off but you need to give it real hard bang for this to happen.
MAS_614
BRISVEGAS
vs executive II
can any1 give instructions or link to instructions to remove the dash itself? not the instrument cluster not the instrument cluster surround but the actual dash ive got everything else removed just need to get the dash out now and cnt seem to figure out how
88GreenVN
Next Exit Left
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
Bolts across the top under the demister vents and 2 on the sides (vents removed)
MAS_614
BRISVEGAS
vs executive II
thnks 88greenvn i ended up figuring that out myself and ive undone them all but it is still connected to the steering column by one lil screw that i cnt get a screwdriver in 2 undo is there sumwhere else i undo something or shud i jus pull it and it will come out on its own?
Darrin
VS Acclaim
Hi folks I have a VS and the air bag cover on the crash pad passenger side is peeling away from the dash and the airbag light is now on so how bad is it ? and i could do with a few contacts on who fix dashes like this in sydney that would be real great if you let us know.
