VS cruise control issues
coolngroovy
Mackay Qld
MY06 VZ Calais
G'day all,
I have a problem with the cruise control in my VS Caprice.
The green CRZ light on the dash stays lit, yet the cruise wont work.
I cant turn it on/off, & none of the other functions on the stalk are working.
I have tried unplugging the fuse, hoping that it might reset, but that didn't work either.
I'm not sure where to start looking.
Does anyone have a suggestion?
Cheers, Col.
accentstencil
69
Eschol Park, Sydney
WH II Caprice, 5.7 2018 Equinox LTZ V
Since none of the controls on the stalk are working you might need to replace the stalk.
ironhorse
vs calais
I have the same problem with my vs calais, so i too would like any info on fixing this.
Is the stalk hard to replace?
xitekamelion
sydney
1996 Vs S2 Ecotec Equipe
iv heard that if a brake globe is blown it can cause problems, try checking those.
coolngroovy
Mackay Qld
MY06 VZ Calais
All the globes are working. So lets eliminate that!
Fortunately the Caprice has a "Hey idiot, one of your globes are blown" warning light.
Just to be sure , i checked. LOL
Thanks for the input guys, keep it coming.
markovr
60
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
Because the cruise light comes on means the power to the stalk is ok and the feed out turning it on is ok but you need the on light to come on from the set button...it is common for one of the small wires to break off inside the stalk....and the brake switch not being adjusted properly causes the same fault.
00vxsc
qld
VX L67, ln106 hilux, xr600r
my VR did this, swap 1 of your relays and try that..
hako
Donating Member
78
Toowoomba SE QLD
VS11 BT1 V6
If you cannot turn the green CRS light off that would indicate a problem with the stalk which is not hard to replace - new ones are about $60 on Ebay for a genuine one.
You also say you pulled the fuse to reset it - you may need to disconnect the battery as the fuse you pulled does not reset the electronics in the BCM and ECU....may be worth a try.
ss1977
VS Berlina + LX Captiva
Cheers guys, i will try today.
Did you have any luck?
I have the same issue... I would say it is the stalk as my son was playing in the drivers seat and was using a fair amount of force on it. It wouldn't surprise me if one of the wires snapped off inside it.
I was going to buy one off eBay and re-install it to see if that fixes the problem.
Does anyone know of a "how-to" guide on this forum for replacing the cruise / indicator stalk?
