vs cut out while driving
Discussion in 'General' started by knight_vs, Feb 17, 2012.
  1. knight_vs
    knight_vs New Member
    svz ute
    guys on my way to work this morning i would not have made it 2km before my
    vs v6 decided to cut out it felt fuel related like it was choking coz of no fuel
    but i have plenty all warning lights came up transmission, battery and engine
    please any help would be apprectiated cheers
  2. Dr HaxZaw
    Dr HaxZaw New Member
    R34 GT-T
    Check your fuel filter?
    Also is it an auto or manual?
  3. Ghost
    Ghost Donating Member
    Junee New South Wales
    Vs Commodore berlina Sedan 1996
    From what I see you may need a new abs module
  4. knight_vs
    svz ute
    the racv bloke reckons crank angle sensor the mechanic im at now says
    fuel pump it definately felt like no fuel was gettin to the motor but tranny light came on first
    so im not sure lucky i have free roadside assist
  5. knight_vs
    svz ute
    its auto that has been recod and shift kitted no less than 10000ks since
  6. Ghost
    A faulty cas wouldn't create the dash lights issues when the abs module starts to go it shows signs of a faulty fuel pump and cas but see how u go if the problem happens after the fuel pump then start with the abs module for sure
  7. knight_vs
    svz ute
    ok cool still waitin to hear back from the mechanic is the abs module an easy fix
  8. Ghost
    If you can get one yes the module is behind the drivers side kick panel
  9. MikeCuzzy
    MikeCuzzy Jumping puddles
    Australia
    2007 VE Omega 3.6L
    Check coil pack, the connections on mine come loose, I lose all engine electrics - doesn't sound exactly like your problem, but I thought worth a mention.
  10. knight_vs
    svz ute
    well guys turned out to be crank angle sensor and ignition coil pack coz i was selling the car this weekend i got a roady at the same time now i have a worthless vs because its gonna cost big bucks to fix no thanks to the previous mechanic who obviously did not see these problems last year im screwed
  11. VS_Pete
    Good luck mate
  12. knight_vs
    svz ute
    well ill just repair it stuff it then get rid of it
  13. Dr HaxZaw
    R34 GT-T
    how much is a new crank angle sensor?? i didnt think they were that expensive
  14. knight_vs
    svz ute
    sorry for the late reply 58 bucks dude
