vs cuts out for a split second
beefcream
Lethal LOKKA
34
South,Adelaide
VS SS 5speed (project) VN exec v6 (daily)
hey all,
have a weird problem every now and then, did it once this morning so hence writing this. my ss seems to randomly cut out for a split second randomly. often seems to happen couple minutes in morning after first start up. its like the car turns of for a breif moment, the cd player turns off and the abs light shows then it revs up a tiny bit and is as normal
any idea why this would happen??:bang:
VrWagz1
The Wagon on Wheels..
wollongong
www.wagzhome.justcommodores.com.au
VE SSV MY09 Auto Wagon
thats an odd one, it sounds like a dodgy connection somwhere, pull the efi relays and have a look at them. But i recon have a quick scan over the running ccts and fuses.
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
Dunno if this is what's happening, but my VS will 'test' the ABS every few minutes....if this happens with the engine cold it makes the revs drop 100 or so for the 1 second the test takes. Not sure why the revs do drop - I know the ABS motor drags a fair amount of power. I'm also not sure how often this test takes place but I do know the ABS does test itself.
Also do a codes check - instructions attached:https://forums.justcommodores.com.au/threads/checking-error-codes-vr-vs-revised.22307
