VS Cylinder compression low on all 8 cylinders
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by fayo, May 21, 2012.
  1. fayo
    fayo New Member
    mackay
    comodore vs 5 litre
    Hi my problem is car just stopped on highway.The RACQ towed it to my mechanic at the time it had spark but no fuel pressure,replaced pump then he said there was no spark tested ognition module ok rings me up a few days later and tells me it now has fuel and spark but wouldn't fire he checked it for compression and informed me there was was only a maxium of 100psi to 110psi oall eight cylinders and I would need a rebuild or replace the motor. Has anybody ever had this happen to all 8 cylinders, as it was running fine before, it wound over had spark just and wouldn't kick in.
  2. NeilB
    NeilB New Member
    VR Caprice
    Strange thing to happen to all cylinders at once, very strange actually. Get another opinion!
  3. VR38
    VR38 Well-Known Member
    VB SL/E
    It should still fire, even tho the compression is a bit low it is still even across all cylinders so should still fire and run, just will be low on power.
    Get a second opinion.
  4. fayo
    fayo New Member
    mackay
    comodore vs 5 litre
    The mechanic tells me it needs more than 100psi to, fire am just wondering what he might have done wrong to maybe cause this, or hasn't checked what might be causing it, to all of a sudden be low on all cylinders?
  5. Decicrate
    Decicrate Member
    BrisVagus
    VS L67
    Get it moved to another mechanic.
  6. fayo
    fayo New Member
    mackay
    comodore vs 5 litre
    That is what I will be doing. Would like to know what would cause it to suddenly not have compression is he not testing it correctly,should he be doing something else to make sure it will get compression eg rings are dry from been continuosly wound over just curious enlighten me with some of your knowledge.
  7. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    hes probly just telling you this so he gets money, or he just doesnt know **** about cars, seriously doubtful that all 8 cylinders would go low on compression at once (over time yes) but it wont cause it not to start
    GETANOTHER OPINION and tell this guy to shove it lol
  8. James39
    James39 Gave up on VL's
    Newcastle NSW
    1995 VS Acclaim & 1992 Holden Barina
    I think the point they are telling you is that your mechanic is probably telling you bullshit.
