VS dash wiring
alajhotrod
Kempsey
VS Caprice
Hi just fitted L2 dash and wiring back in and Airbag light will not go out when ign. is on any idea what i have done wrong? thanks Allan:lock:
88GreenVN
Next Exit Left
60
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
If you turned on the ignision without a cluster in the car it may have tripped an SRS error code. (not totally sure on that tho)
alajhotrod
Kempsey
VS Caprice
No every time i pull dash in or out took battery off but to get that checked out do i have to go to a Holden dealer Shane? thanks Allan.
88GreenVN
Next Exit Left
60
Surprise, Arizona
If it's logged a code for the SRS it may well need to be removed by a mechanic that has a tech 2 tool. (removing the SRS warning globe is not recommended)
