Just a headsup. Some of you may know anyway. The Series I & II are different so I found out. The bracket and actuators are different. Also the wiring plug is different. I got a brand new lock and actuator for the passenger side/front. You can still get new ones up to VZ. Here is a pick of both. May help people getting right part off ebay ect. ect. I`ll post part numbers of each door tomorrow. Parts like the Photo.
Really? I've had series 1and 2 VS and never had an issue. Although I just buy the actuator itself not the whole assembly. Clubby currently has brand new VN actuators.
Yes that`s ok it was cheaper to buy the whole thing. As you can see the top one is the one taken out the car. The bottom one is out of a donor vs door. I don`t know was it the last vsII it changed? Anyway I got the bottom one out for the panel beater to put in as you can see it didn`t fit and couldn`t swap the actuator over the plug is different also.
Weird how that works hey. I got really really lucky, was new old stock, set of 4 actuators still in their box for $40. Couldn't believe my luck.
Part Numbers lock/actuator complete part refer top part in pic. above. Right hand front 92187611 Right hand rear 92187613 Left hand front 92187610 Left hand rear 92187612
