chasha15
Hi guys,
I need to replace the driveshaft centre bearing on my 1996 VS 6cyl/manual ute. I've spent some time searching this forum, youtube, and the workshop manual and i'm getting conflicting information. I do understand that you need to mark everything so that you can re-assemble in the right orientation with correct balancing, but i'm confused about:
1. Do i need to remove the entire driveshaft (transmission to diff) before i start contemplating removing the centre bearing? or can one section and not the other be kept attached to the car?
2. Do i need to disassemble the CV joint (6 bolts, circlip) to be able to remove the centre bearing? or can I do what i've seen on youtube and just hammer the front driveshaft out, achieving access to the bearing, and then re-hammer the spline back in after replacing the centre bearing?
3. will the old centre bearing slide off the driveshaft or will it require a press? hammer?
4. how do you fit the new bearing to its driveshaft? will it slide on by hand, do you need a press, or is a hammer ok? direction-wise is there only one way it fits or is there something to keep in mind? any lubricant required?
Thanks
Thanks
