strgas
GRA = REAL HP
- Oct 23, 2009
- 1,503
- 63
- 48
- Location
- 3666
- MERC W124 / toys WB tonner WB Panelvan project
common problem to check is the purge hose under the throttle body to the purge valve as this often falls off from backfire and will introduce a vacuum leak which wont affect petrol running to badly but cause LPG running rough surging and stalling , if this hose has come off I would recommend you replace it with a single piece of vacuum hose and if backfiring to change the spark plugs to a NGK BP6EFS with a gap of 1.0 to 1.1 mm
