VS dying
05 Senator
Norsey
VL Calais RB25 turbo, VS Calais
Hey guys I've just bought a VS calais and have a small issue with it. The guy before me supposably replaced the motor and transmission with ones from a VT.
The car travels fine when driving normally however when i tried to do a nut on the gravel it died about 3/4's around. I've tried it in 1st, 2nd and drive and with power on and off and it died every time. Its starts straight away after doing it but revs at about 2,000 rpm and slowly drops back to idle..
Any ideas?? Thanks in advance :)
Joe
ephect
Donating Member
VS Acclaim V6
Which way U doing ur nut? Left or right? Could be staving for fuel..
05 Senator
Norsey
to the right. I KNEW there would be something i didn't try before asking lol. Guess ill have to go back and try again ;)
05 Senator
Norsey
nah not that i've noticed yet.. (like i said i've not long bought it..) but it seems to start off fine when doing skids. No problem when drifting corners, only tight donuts..
I'll see what happens tomorrow.
05 Senator
Norsey
yep no problem when going left.. Is there a solution to this besides not doing donuts?
BlackVXGTS
Melbourne, SE
the vt trans has traction control.. have you got the button fitted in the cabin to turn it off?
Traction control is a function of the ABS/ETC system on VT Commodores not the gearbox.
05 Senator
Norsey
bit over quarter of a tank.. if it sucks a gut full of air, it wouldn't start up straight away would it??
