delcowizzid
on holiday
yeah you can go map if you get a dyno tune with kalmaker or you can roll back to the VR auto ecu which runs map as well and can control the electronic auto still
a bored out maf or ls1 maf will both allow for measuring more air as the frequency vs airflow changes you get more air going through for the same Hz frequency getting output to the ecu.its good when the limiting factor is the stock ecu tunes only measuring upto 8Hz of frequency i think it is.so a bigger maf gives you the extra headroom before maxing out the frequency team that up with kalmaker which extends the frequency to 10Hz and you can measure a huge increase in flow.but if you are using the maf on the intake side of the blower it will be sweet to 10psi at least i think.
