VS Ecotec Modifications/rebuild
Discussion in 'Mace Engineering' started by darcycammo, Jun 13, 2011.
  1. darcycammo
    darcycammo Member
    Cockatoo Vic
    Did have VS Berlina now have VT Berlina
    i will upload photo's later the lower half of the engine is back in the car and for the next couple of hours i will put as much as i can back on the engine getting close now
  2. MACE
    MACE Well-Known Member
    Sweeeeeeet :D
  3. darcycammo
    darcycammo Member
    Cockatoo Vic
    HMMM not what i was hoping for it seem's to be missing back fires when you put your foot down even when in idle it doesn't sounds right a couple of coolant leeks and one of the pipes for the gearbox oil that goes to the radiator has a cut in it FML
  4. Wombles
    Wombles Cars cost too much.
    Sounds like it might be out of time. Maybe chack that?
  5. darcycammo
    darcycammo Member
    Cockatoo Vic
    this is what it sounds like i didn't get to run it for long before the gearbox oil started leaking
    [video=youtube_share;5eQJVQqiEl8]http://youtu.be/5eQJVQqiEl8[/video]
  6. darcycammo
    darcycammo Member
    Cockatoo Vic
    More bad news by the looks of it water in the oil would the engine assembly lube make the oil turn white this thing is shitting me now
  7. MACE
    It could be drawing in water into the intake. By the sounds on it you have water mixing with the oil somewhere. Likely the inlet manifold gaskets or head gaskets
    Also make sure that you have the spark leads in the right order.
    Cheers,
    Steve
  8. darcycammo
    darcycammo Member
    Cockatoo Vic
    The reason for the backfire and shitty idle was because of the spark plug leads i had on it i put another pair on and it was fine the main problem now is when you go to put it in anything other then P / N it just stalls unless you rev it a bit but as soon as you take your foot of it stalls
  9. MACE
    How does it idle in those gears?
    You may want to consider cracking open the butterfly a little bit more then factory
  10. darcycammo
    darcycammo Member
    Cockatoo Vic
    in P or N it idles fine but if you rev it then just let it drop it goes to stall but in like D or R you have to keep your foot a little on the accelerator otherwise it just stalls
  11. MACE
    Consider cracking open the butterfly a little bit more then factory and see how that goes
  12. darcycammo
    darcycammo Member
    Cockatoo Vic
    Well first i have to find out where this coolant is getting into the oil just took the sump plug off and it is fully white LOL
  13. darcycammo
    darcycammo Member
    Cockatoo Vic
    I think the problem is the VX heads that i put on it. so i will give the VS heads a clean down change the springs over and put them on
  14. MACE
    Before you pull anything off if you borrow a coolant pressure tester if may save you a HEAP of time!
    I say this as it my not necessarily be the heads for arguments sake.
  15. darcycammo
    darcycammo Member
    Cockatoo Vic
    :S There already off LOL oh well
  16. MACE
    Well all I hope is that you find your problem :D
  17. darcycammo
    darcycammo Member
    Cockatoo Vic
    okay this is just shitting me now i have put it all back together to fill the coolant up and before i even turn the car on the coolant is already leaking out of the back of the passenger side head fml
  18. MACE
    Did you use new or used cylinder head bolts?
  19. vsv6dude
    vsv6dude Member
    vs v6 wagon
    Just come in late on this is anyone (qualified and experienced) supervising or overseeing your work and approving the proposed process you are using ?
  20. MACE
    It's more of a learning curve for Darcy, from my understand, to complement his trade apprenticeship.
    As the saying goes, you have to break a few eggs to make an Omelette :)
