VS Ecotec Modifications/rebuild
darcycammo
Cockatoo Vic
Did have VS Berlina now have VT Berlina
okay i came across a little bit of a problem today when i went to put the conrods to the crankshaft as i had to use the bolts from the VS conrods they wouldn't fix on the VX ones so im going to have to clean the VS pistons and swap the new piston rings over to them and use them now got a big shopping list for tomorrow
MACE
Are you 100% sure? Maybe the bolts were damaged, please confirm this when you can
darcycammo
Cockatoo Vic
The to bolts on the side are the VS ones the one in the middle is the VX i cant use the VX ones as when i tried to get them undone the first time i rounded most of them where is i didn't with the VS ones
darcycammo
Cockatoo Vic
""NEED""
engine oil
gearbox oil
brake fluid
coolant
couple of water pipes
radiator
02 sensors
spark plugs
double row timing chain
105lb springs
exhaust
extractors
""WHEN I GET SOME MORE $$""
rocker's 1.9:1
manifold spacer and insulator
""Do i really need these?""
Valve Locks
Valvespring Retainers
MACE
Looks like you’re well planned for the rest of the build
Some of the service items are straight forward so there is no need for us to elaborate on. Will make a couple of constructive comments, in regards to the aftermarket/performance items though
""NEED""
<<ONLY use a rollmaster item!>>
105lb springs <<if you’re going a double row chain set then go the 130lb springs instead>>
Exhaust <<brands are subjective, I’m usually a fan of a redback systems>>
Extractors <<can get away with using your factory headers if you’re on a budget>>
rocker's 1.9:1
<<will not work with the supplied cam. Would need something like a 1.75:1 item instead which we can supply>>
manifold spacer and insulator <<ideal combo would be a 12mm plenum and a 25mm manifold insulator (depending on space). Fortunately can easily be installed at a later stage>>
If you have any more questions please don't hesitate to ask.
Kindest Regards,
Steve
darcycammo
Cockatoo Vic
Does any one know if HITECH EXTRACTORS are any good as i can get a pair pretty cheap.
spauldj308
S Pack Man
Hobart, TAS
VR S sedan 5L, VSII ute
I have hi techs on my VR, an improvement over stock and ok for the price, but there are better brands out there
