primo
- Sep 10, 2009
- 30
- 0
- 0
- VS Commodore
DFI pull it off and clean all the contacts, checking coil resistance doesn't really mean anything, when under load is a different ballgame, was the oil seperator under the pcv put back in correctly with the hole facing into the manifold? Smoke could be burning coolant from a leaky intake manifold gasket, very common on these engines.
I actually didn't pull out the oil separator just the PCV valve and spring was taken out and cleaned.
I have changed the intake manifold gaskets..........the white smoke under hard load has been there for a couple of years.
Thanks for the purge solenoid pics.
