Drawnnite
Obviously Unsensible
- Sep 2, 2010
- 2,030
- 2,151
- 113
- Location
- Victoria
- 2000 Vs Ute
Simple question, Engine (ecotec) is out to fix up a bunch of stuff, wanting to know what would be recommended to tackle while its out.
No conversions etc are on the cards for now, its a daily that is soon to crack the 500 mark, still going solid.
Before pulling it out it ran smooth, just had a bunch of typical leaks.
Current list has
Visual stuffs
-Touch up paint in the bay
-Clean off years of oil/dirt build up from small leaks
Mechanical
-Power Steering Res and Hoses
-Radiator and Hoses
-Water Pump
-Thermostat and Housing
-Clutch Slave.
-Clutch Pedal bushings
-Oils (Gearbox inc), Coolant, Power Steering fluids
-Filters/Plugs (General service stuff)
-Rear main seal and plate
-Engine Mounts
-Knock sensor plugs (Busted 1 taking it off)
-Driveshaft Diff Bolts Any suggestions on where to get these?
-Reverse Light Switch
-Short Shifter (Its a getrag afterall)
-Oxy Sensors
-Exhaust Manifold bolts
-New gaskets for whatever is easy to get to while on a stand.
Thoughts on stuff like redoing some of the split conduit or other elec loom stuff or any other hoses/clamps or hard to access bits?
Any other motor ancillaries?
Harmonic Balancer?
Not considering the following
Steering Rack will get done down the track.
Idler pulley, Belt and Clutch are reasonably new so not in this project.
Air Con was fixed 2 years ago so that runs well.
Brakes are good has newish booster and that side of it.
Current list has
Visual stuffs
Mechanical
-Radiator and Hoses
-Water Pump
-Clutch Slave.
-Engine Mounts
-Oxy Sensors
Harmonic Balancer?
