vs error code
yoshi87
south australia
vs commodore
hey guys, got a vs wagon, it has started pl;aying upwith some error codes, want to know how to fix them
42 - circuit bypass
Code 47 - 18x Reference Signal Missing
Code 48 - Crankshaft Reference Signal Missing
Code 49 - Cam / Crank Shaft Signal Intermittent
any help would be great, thinking the bypass crank and cam shaft is part of the sensor for the crank
cheers in advance
K-BAGZ
De Plane! De Plane!
Far North QLD
VR II S-pac V6 Ute / VZ SV6 Sedan / VZ R8
Replace the Crank Angle Sensor (CAS).
Refer to How To section.
yoshi87
south australia
vs commodore
no worries, ill be looking at doing i t this weekend, plus thats wat i thought it was
Jxfwsf
Aus
commodore
could be the dfi module with the bypass error code & cam angle sensor, i'd be looking at that first
bypass is to do with the dfi module
cam angle sensor is separate to the crank angle sensor
both crank and cam sensor go straight to the dfi module.
dream888
VR V8 BT1, BMW Convertible
Yep, Crank angle sensor
K-BAGZ
De Plane! De Plane!
Far North QLD
Direct Fire Ignition module. Coil packs sit on top of this item.
