Vs exterior door handle removal
dobai
30
Werribee
Holden Vz Storm Ute
Does anyone know how to remove the door handles on a vs ute, had some vague descriptions of how to do it but something more detailed would be great, cheers.
yoshi87
south australia
vs commodore
should be the same as a normal front door, remove the door garnish, look for the 2 nuts holding the door handle on, undo them pull handle out as u remove the handle and replace the new handle be sure to fit the handle into the locking mechanism that allows u to open the door by the handle
dobai
30
Werribee
Holden Vz Storm Ute
thanks, ill give that a go, a lot more detailed than, pull a pin with plyers and it comes apart haha
Pollushon
Boost gives me a bar....
VY SS
The VS doesn't use bolts, it's a two piece handle held in by a clip pin that slides out. It's fairly obvious once the trim is off, a flat head screwdriver will do the trick.
Maybe someone has a guide/write-up or way better memory, but if you want dobai, take a pic internally and post it up, should jog my memory to the exact method.
It's actually pretty spot on :) It's one of those things, that if you're even slightly mechanically minded and you have a crack you'll figure it out in a blink.
timd29
VE Calais V S1 International 6.0
Couple of good videos on you tube showing all steps for this.
