Trevor loves holden.
- Jun 6, 2019
- 3,508
- 750
- 113
- Location
- Victoria
- vs commodore
Amp doesn't make it cleaner, good quality speakers do that, Amp just means more power without distorting the speaker via the headhunt max out volume.cleaner signal if you use an amp
Better off buying a good set of cross overs and piss off the crap you have in the front. If you want to Amp your speakers do it from the back parcel shelf.
Like I said for both front door speaker to stop like they did at once is strange, if there was a problem like a earthing out wire it would shut down the whole speaker including tweeters on that line.
Without seeing the set up how they wired it then it be better to run new wires to the doors, just cut the speaker wire in the kickboard side and tape the new ones to it and pull them thru from the door.
