Vs Feels Different
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Gobbles, Jan 8, 2004.
  1. Gobbles
    Gobbles New Member
    North Gold Coast
    VS Acclaim Series II
    my VS has just recently started to feel laggy and not very responsive......id give it say 25% throttle and it takes 3 seconds for it to start giving any power of any kind....
    its got 134000k's on the clock and hasnt been thrashed except for 7 burnouts since ive had it and bought it off elderly people......so not sure whats wrong with it.....anyone have any ideas ?
  2. holdenlover
    holdenlover New Member
    How long has this been happening??? Bad fuel maybe?
    Have you run a self test?
  3. Gobbles
    Gobbles New Member
    North Gold Coast
    self test being ?....
    i run nothing but BP Ultimate so if thats dirty ......
    first thought was fuel filter......only started noticing problem yesterday...like it feels like its tired and slugish and its getting on my nerves
  4. holdenlover
    Sorry.......by self test I mean, the computers diagnostic test (sensor faults etc)
  5. OSL-060
    OSL-060 Banned
    SE QLD
    Has your ECM light (check engine light) come on at all?
    Sounds like it just needs a good service if the light hasnt been on.
    Do oil and filter, fuel filter, air filter, plugs, check the leads resistance and replace if necessary.
    If it's still a little sluggish, I'll give you a spreadsheet on extracting the ALDL codes and related jargon that will guide you through the process.
    Jake
  6. Gobbles
    Gobbles New Member
    North Gold Coast
    alright thanks for that
    2moro's mission is to get a K&N Panel Filter......new leads, new oil filter, plugs (if on the box it says for VS 3.8L do i have to adjust the gap or anything ?)
  7. OSL-060
    OSL-060 Banned
    SE QLD
    *Yawn* Last post before bed and because I know you want to go shopping in the morning.
    The plugs you get should be gapped to a reasonable gap as is. Look through the NGK book and you'll find them.
    Get a fuel filter and some throttlebody/Carby cleaner also- if you have the money.
    DONT buy Valvoline Filters of any variety, stick to Ryco if possible. Better quality not to mention being Australian made and owned.
    Jake.
  8. Gobbles
    Gobbles New Member
    North Gold Coast
    hehe im not sure if i can change the fuel filter just yet...ill be fine with the oil and filter......and air filter.....and plugs leads actually how do i know when the leads are tightened isnt it 3 turns with a socket and then loosen it half ?
    i should have enough...i got a $240 police fine to pay i hope i get good behavior but yeah......$350 to cover all of the above
    cheers mate
  9. Grantis1976
    Grantis1976 Guest
    I think the "7 " burnouts may have something to do with it. It doesnt take long for the rings to get distorted when smoke'n the bags.
  10. ashdeni
    ashdeni New Member
    QUOTE (OSL-060 @ Jan 8 2004, 09:43 PM)Has your ECM light (check engine light) come on at all?
    Jake
    My VS has the same problem. It is regularly serviced (every 3 months) and has not been thrashed. Can you give me a spreadsheet on extracting the ALDL codes? What exactly would this do?
    Cheers,
    Ashdeni
  11. OSL-060
    OSL-060 Banned
    SE QLD
    Ashdeni, Garth has pinned all the extraction info and code spreadsheets in the appropriate sections. You'll find them
    BTW- Welcome to Just Commodores bud
    Jake
  12. fitykemp
    fitykemp VH SL/E 1981
    81 SL/E
    remidy
    give ya a hot tip, fuel filter and or fuel pump, happend to mine, replaced both these and it runs like new, also removed throtle body and IAC and fully cleaned them, made a huge difference.
  13. Fekason
    Fekason Fekason
    Penrith NSW
    Injector Clean
    It is more expensive than some of the other options, but it could be that the injectors need a good clean.
    Perhaps a bottle of injector cleaner could be worth a try, but it might need a professional cleaning act.
  14. try cleaning Throttle body out, the butterfly sounds like its a bit sticky CRC carbclean as mentioned before works a treat.
