VS Front strut problems
pomiedore vs
sydney
vs acclaim series 11 v6
I have just installed a new set of struts to my front suspension.
Everything went back together the way it came off, ie, washers , mounts, nuts, etc.
The only problem now is that the locating washer sits around 5mm higher than it used to.
When I bounce the front end I can see the locating washer moving up and down.
All nuts are tight and the bearings, bushes are new.
All parts are standard for a VS series 11.
Have I missed something ?
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
Did you put the washers the right way around? The cup washers go a specific way. Also make sure the first nut (the bottom one under the metal plate with the rubber ring on it) is tight.
pomiedore vs
sydney
Yes.
The first washer went in as an inverted cup , then the bush and bearing, then the next washer went in as normal cup( like this U ), then the nut tightened all the way down, then the locating plate and nut.
