VS Handbrake Button I'm stumped???
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by Mike67, Dec 14, 2012.
  1. Mike67
    Mike67 New Member
    NZ
    VS Wagon
    The handbrake button on my VS popped off while I was vacuuming the front. Spring flew out and the steel rod that comes up the middle of the lever dropped down. Searched the problem and have done what others have posted but the steel rod will not come up the whole way so I can put the button back on. With a heap of effort I have got it about 25mm from the top. What am I doing wrong ???? Any help most appreciated.
  2. Maxmadmat
    Maxmadmat Member
    Rotorua, New Zealand
    VR Berlina Wagon 3.8 & VS Sedan Manual 3.8
    So are you saying the steel rod sits 25 mm in from the end of the handbrake lever? If so this is normal. Rod (as you may have found in your searchs) is lifted up by puting a finger up under the slot beneath the lever (should just be able to touch it, easier with the rear console removed from memory) once lined up properly, poping the button back on should not be an issue.
  3. Mike67
    Mike67 New Member
    NZ
    VS Wagon
    Thanks for that. I've removed the console to make it easier to get at. I guess you mean the long slot that runs the length of the level underneath. I had to use pliers and pull the rod up as far as I have got it. The button is 22mm long and the rod is still 25mm down which means it still is not high enough. Is there anything that could be causing the rod to jam. Cheers and once again any help much appreciated.
  4. Maxmadmat
    Maxmadmat Member
    Ok I am going to have to have a look at mine later on, but just a thought... The plastic handle itself hasn't perhaps moved forward?
  5. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    As above, the plastic handle can slip forwards on these. Mine does it.
  6. Maxmadmat
    Maxmadmat Member
    Ok had another look at mine... If you look in the hole where the button goes, the plastic handle (the peice you hold when you pull handbrake on) has a depth of 1.5 mm or so of plastic, this then sits flush against the end of the metal body of the handbrake lever, is there perhaps a gap here? If not your problem is at the other end of the rod. The other end sits against a spring loaded cam with teeth on it, this in turn engages teeth on the handbrake lever. Can you pull up the handbrake, does it click? Can you release it by pushing on the rod? Because it is possible the metal rod has either moved off the cam... Or the cam has fallin out.
  7. Mike67
    Mike67 New Member
    NZ
    VS Wagon
    Yep thanks very much. That was exactly what had happened. The rod had fallen off the cam. I couldnt see how it worked until you asked does it click. Once again many thanks...all fixed other than putting the console back tomorrow.
