Hi All.....I bet there's a thread on here about this but i haven't found out, anyway's are the Vs Berlina heater controls prone to faults? Mine work's when it feel's like it, if your lucky it might go straight away but more often than not will take 10 to 20 minutes of driving before it kicks in. It's just got a blank screen then all of a sudden it will start working again, thought i'd ask if this is a common fault on these as i see a lot of these advertised for sale & am picking this one might need replaced to. Cheers for any info Dave
Just to clarify your reference to a "blank screen", does your VS Berlina have climate control? As far as I know, in Aus it was only available on VS Calais/Statesman/Caprice.
Yeah it's the digital climate control on this, it's like it's getting no power to it. Just not sure if i need to replace it or if there's something can be done with them. Sometimes it works straight away but other time's it take's ages, just a pain when your windows start fogging up in the rain..... Is the lamp check relay connected to the climate control power source?
lamp check relay has ignition feed running through it. just remove the relay, and bend the pins in a little.
