Vs help
vswagow
VS Wagon VS
Hi guys im new here.
I have a vs wagon on gas. It is running shocking on petrol and perfectly fine on gas. when it idles on petrol it sounds like it has a lumpy cam in it.
Here is a video of the car. would be great if you could help or tell me how to fix.
Cheers:thumbsup:
SV62NV
Scuba Steve
Kurunjang
MY09 VE SV6
my mate had the same problem with his car, he went and bought a normal exhaust and the problem stopped, mite not be the same with u just a suggestion.
cheers, shane
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
My first though is one or more dirty injectors as you say it runs OK on gas (rules out ignition) - put a can or two of injector cleaner thru the tank and see if that improves things. It's not blowing black smoke so it's not running rich.
And welcome to the forum.
vswagow
VS Wagon VS
thanks guys will try injector cleaner and see how things go.
Could it also be a dud valve or not?
cheers
RedGoesFaster97VS
Perth,WA
96 VS Executive S II
I have the same issue on gas, runs soo bad but fine on petrol, sorry i cant help tho, i still trying to figure mine out =)
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
cheers
A dud valve will be felt on gas as well - as it runs OK on gas the valves must be OK. May also pay to replace the fuel filter as a long shot...probably due anyway!
VrWagz1
The Wagon on Wheels..
wollongong
www.wagzhome.justcommodores.com.au
VE SSV MY09 Auto Wagon
That sounds so very wrong, giving it runs on gas fine i would say check out the fuel system. As said injectors would be high on the list.
