NORTI
- May 22, 2004
- 3,422
- 5,155
- 113
- Location
- Radelaide
- Wildtrak
HSV Brake upgrade. Help needed
185 Senator with factory standard brakes, previous owner switched rotors & calipers to the VT, but never changed the master/booster.
always had a shitty pedal - assume from keeping VS setup.
flash forward, car has sat for a bit, get in, no pedal. get it sent off to workshop, and since I have to have the brakes fixed, I hand over the HSV 215 brakes I have here, supply the rotors, calipers and brackets.
workshop tells master is leaking - sounds about right for the behaviour.
So by my reckoning, HSV brakes get a refurb/reseal, and the standard master gets a rebuild, and everything should play nicely? Not so, master is still leaking, now I have workshop, & master cylinder rebuilder fighting about the issue.
every thing I have known and even to read the HSV service guide, says that the HSV upgrades are at a wheel level, and retains the standard booster & master.
someone back me up or tell me I'm wrong so we can move forward?
