VS ignition barrel broken. Need to start her.
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by moondog450, Mar 12, 2010.
  1. moondog450
    moondog450 New Member
    VX Berlina S2
    Hi, the trusty old Vs is sitting in a shopping centre carpark. The key will turn all the way, but the spring mechanism seems to have dissapeared and the car wont fire. All lights come on the dash so we have power. Just the bit that cranks is gone. (it's not the park switch or battery either, definately the barrel is flogged out) Now the management is on my case to remove all of her $800 glory so I need to pick it up tomorrow somehow. I know I will need a replacement barrel which is fine, but I'm thinking that if the key/barrel is providing power, shouldn't I be able to arc the solenoid on the starter and give her some life? Perhaps a little hotwire job is the go. I don't mind if I have to brake anything. Any tips or advise before the morning will be very much appreciated. Cheers.
  2. Fonzie
    Fonzie Just lost the game.
    You've checked the starter motor circuit right...?
  3. moondog450
    VX Berlina S2
    The problem is the ignition itself from what I can gather. Before it died, turning the key became a bit sticky. What it does now is, key goes in, turns onto ACC, turns ontp ON no worries, and then the next turn to the engine crank (the spring return part) is not there. It simply turns forward with nothing and no return back to the ON position. Turn all the way back to OFF and the key will come out but sometimes the ACC are still on. I noticed the radio still on so I have disconnected the battery while she awaits her faith.
  4. NeilB
    NeilB New Member
    VR Caprice
    Tilt Tray. Easier than the mucking around.
  5. westbad
    westbad New Member
    earth your starter out and it will crank over. ;-)
  6. moondog450
    VX Berlina S2
    Cool westy. Thanks for the backup.
    The tilt tray is out of the question, as the mucking around for 5 minutes, far outweighs the 80k journey and the $$$$$.
  7. RX25SE
    RX25SE Real cars are steel cars.
    MY07 Liberty 30R Spec B 6sp wagon
    Sounds like the stoooopid ignition barrel has busted and will need to be replaced. To get you going, drop the lower steering column shroud and remove the ignition switch (two small screws), turn the key to the 'start' position (to unlock the steering) and use a small screwdriver to rotate the switch and start the car. You may need to remove the broken bit of the barrel from the switch first.
  8. VSColl
    VSColl New Member
    Geelong, Vic
    VS Vacationer
    The same thing happened to me 3 weeks ago but the key jammed in the start position and broke the starter motor.
  9. impulsive
    impulsive Alloytec Racing
    Brisbane, QLD
    VZ Alloytec
    It sometimes takes a few goes to get my VR started, how ever i believe it might be the key. It turns all the way, sometimes with no response, if i pull the key out and try again i usually have some luck!
  10. RX25SE
    This a common fault with VS. Try tightening the main cable nut on the starter motor solenoid.
  11. impulsive
    Brisbane, QLD
    VZ Alloytec
    sorery to hack this thread for a second, but where is this, pictures would be good!
  12. moondog450
    VX Berlina S2
    Righto, I simply turned the ignition to the on position and arced the solenoid from under the car behind the front wheel and she started sweetly and got her home. Took it apart and the end of the inside of the barrell had broken away from the switch with the spring in it. Gee that barrel can be a bugger to pull out even after pushing the pin in to release it. Wreckers on Monday morning for a replacement. If I get a key and barrel, I'm assuming I can just change the head/buttons of the original key over to the new key and all should be sweet.
  13. RX25SE
    You can buy a new 'uncoded' barrel from Holden for around $60. You then are able to use your existing key. Im sure a DIY on this would be in here somewhere.
    As this is a common problem, using secondhand parts may mean this will occur again in the near future. You will still be able to recode a secondhand barrel to match your key.
  14. moondog450
    VX Berlina S2
    not a bad idea RX, might be the way to go.
  15. Brett_jjj
    Brett_jjj Well-Known Member
    Tamworth NSW
    vs commodore
    Never heard of that.I always thought you have to get the key cut to match the lock.If they sold a lock barrel that was a universal fit for anyones key,then anyones key would open or unlock it..
  16. accentstencil
    accentstencil Well-Known Member
    Eschol Park, Sydney
    WH II Caprice, 5.7 2017 Captiva.
    It is not a universal fit, the barrel has to be coded to suit your key.
  17. Brett_jjj
    Tamworth NSW
    vs commodore
    I never heard of a chip in the barrel of a commodore ignition switch.I know theres a key reader around the outside of the barrel (2 metal contact rings)that reads the keys security code,this key reader is connected to the BCM for security.(Immobiliser).This code has nothing to do with the ignition lock barrel.Anyone else know anything about this?
  18. accentstencil
    Eschol Park, Sydney
    There is no chip. When you buy a new barrel it comes with many little bits and piece that I do not know the name of, these need to be fitted in the lock cylinder in the correct sequence to suit the key. This is usually done by a locksmith as they know how to do it. Perhaps the correct word for this is not "coded" and this is causing the confusion. We are talking about coding the key and not the key remote.
  19. Brett_jjj
    Tamworth NSW
    vs commodore
    Right,I wanted to know as Im looking at replacing my ignition lock because it gets stuck when turning it from off to on,and is slowly getting worse.Getting a new key cut didnt make any difference either.I dont want to have to go through the crap of changing the igniton lock(different lock and key) and then have to change the door and boot locks as well,I just want to change the ignition barrel and use the original key.So this new "blank" barrel might be the way to go.Thanks for the info.I will post how I go with it.The little pieces inside a lock are called tumblers and they are different lenghts to match the high and low spots of the key.
  20. accentstencil
    Eschol Park, Sydney
    Get it replaced before it get to the point where it won't turn any more making it very difficult to remove. Many locksmiths carry these barrels now and they will set it for you and it is usually a lot cheaper than buying one from Holden and then having it coded.
