Vs ignition
the_boozer
no more VK
51
Shitsville Morwell
hilux
Whats the correct way to undo the shear bolt on a vs ignition switch the last time I changed an ignition switch on a vs the car was dunger so I covered up abit and got the mig out and tacked a bolt onto it so I could undo it , I would of bugised around for an hour b4 i tuned into bodge. This car has a nice inertia so bodge and the welder can't come out ,its a hundred miles away what should I take with me to undo the shear bolt
vc commodore
Like the Leyland Brothers
VC, VH and VY
You could take a cold chisel, or solid flat bladed screw driver and hammer.....
The way I removed shear bolts on other make ignition switches was to make a slight notch on the end of the bolt and with a screw driver and/or cold chisel in the notch, hit it in the direction a bolt would undo....
vs-lover
VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
Pretty much the same as I've done except I use a very sharp centre punch to dig into the bolt head and use a small hammer and tap it in an anti-clockwise direction. It doesn't take much to undo it.
the_boozer
no more VK
51
Shitsville Morwell
hilux
I all ready put the cold chisels and centre punch In the car i changed the bmc on the thing a while ago now the ignition is gone apparently , the old uncle cant get the shear bolt out.
I like your confidence you and vc would of both laughed very loudly the last time when I turned into bodge it was 8 years ago and I still remember it was my ex's car and all I wanted her to go was go away at the time anyway this car isn't a mobile ashtray so lets hope I can undo it without to much industrial swearing. The good part is I know once I drive it Ill end up bringing it back to the workshop and doing tyres and brakes and what ever else we find it probably hasn't been on a hoist in 10 years
vc commodore
VC, VH and VY
Nah, wouldn't have laughed at you bodging things to get the end result required.....Might have laughed at you wanting to move the ex on quickly though :D
